Removing residue off of paint?
  • Removing residue off of paint?
    I have some residue leftover from the paint cleaner (A3016) that is now dry and cannot remove it with soap and water. My searches have turned up this thread:
    Thanks to the advice of a couple of members I did the clay and three step clean, polish and wax, and the outcome is absolutely beautiful. Unfortunately, as I said in a previous thread, I am not into this as much as some of you guys, and just wanted and nice shiny black car. Soooo, I did not tape any of the molding, and as
    However, it seems that is more for removing residue off of the vinyl / plastic parts rather than the paint itself. Will those be okay to use or is there another product I could turn to?
    Re: Removing residue off of paint?
    Often times if you have some type of paint care residue on paint and you want to get it off, you can use the same product to re-liquefy and remove the product.
    Just to make sure... you do know that you don't let a paint cleaner dry? You apply it to a small section, work it over the paint and then wipe it off and move on. After using a paint cleaner at a minimum you want to apply a coating of wax or a paint sealant.
    In the Meguiar's line of paint care products, the only products that need to dry are the waxes.
    More information.... love the title of this thread...
    Which products need to dry before removing?
      Moved to Detailing 101 as Hot Topics is a forum reserved for "Hot Topics"
