Foggy Lenses
  • Foggy Lenses
    Folks
    My '01 Accord is starting to develop some fog on the outer surface of the polycarbonate headlight lenses. I'm wondering which way to go: Mirror Glaze 10 & 17 or PlastX? I'm not sure if the lenses have some sort of UV coating, but am assuming that to be the case. TIA for guidance from the experts!
    Gavin Payne
    Re: Foggy Lenses
    I would go with PlastX first. Always use the least agressive method. I have had some success with PlastX in the past. It should take care of your hazing problem.
    Andy
    101impala
    Andy M. Moderator
      Re: Foggy Lenses
      I read from this forum that PlastX is supposed to do the work.
      Do a search on PlastX and you will see many threads on this very topic. This is one of them:
      I gave PlastX a try on this oxidized headlight. After a couple of passes with a cordless drill and foam pad, the results were amazing. It only took me about 15 minutes to do both lenses.
        Re: Foggy Lenses
        I would agree with Andy. Try the plast-x first.
