Ok, I will detail a car probably next week or so.. It's a '86 car so the paint isn't in the perfect condition.. It has a lot of swirls and the paint isn't that glossy anymore... It still has some reflection though. Here is what I'm planning to do to it.
Wash the car.
Clay the entire car.
Apply #83 with DA.
Apply #7 with DA.
Apply NXT with DA.
What do you guys think about the products and order I'm going to use these?
Another question, what are the differences between #82, #81, #80 and #7? They all seem to be like some kind of a polishing product.. Please correct me if I'm wrong.. I know the #80+ has some abrasiveness and cleaning agents.. What about #7?
I've also read Mike Philips's advice on how to use #83 and #7 but I'm a little confused about them..
On the #83, the advice said that let the product diminish or something like that.. It means that I should keep the DA running slowly until the product can't be seem in the paint? It also said that the opposite side of the direction you're moving the DA should still be wet.. Well, if you want the product to go away while applying it with the DA, how will you know if it's still wet? Also, how are you going to estimate 5lbs of pressure force? I just don't want to press it to hard and damage the paint or something..
Ok, on the #7, I've read Mike's advice on autopia.org on how to properly remove the product.. I understand that it shouldn't be removed as a wax and you should go around the car around 2-3 times removing the product applied little by little.. I didn't really understand that process.. There was a special word for it.. I forgot it though and couldn't find the link anymore...
TIA.
Wash the car.
Apply #83 with DA.
Apply #7 with DA.
Apply NXT with DA.
TIA.
