Copying and pasting my post from Autopia..
I picked up a PC from Lowes and pads from (other vendors) this past week, so I naturally had to try my stuff out today!
The PC is MUCH more powerful than my poor little Craftsman buffer. The two just don't compare. Anyone using one of the cheaper buffers would be well advised to upgrade!
I just worked on half of my hood today so I wouldn't waste time doing the entire car in case I was doing something wrong. Today was just a chance to get aquainted with the machine. I taped off the half I was working on so I could compare and contrast the two sides. I really don't have many swirls on my finish, but lots of marring from acid rain and stuff. The car has lived outside for 8 years and been in a couple accidents (repainted panels..), so that's to be expected. I went in hoping that I could reduce some of the problems.
First I used Meg's #82 SFP in a section, but observed that the marring wasn't really going away. So up to #83 DACP w/ a polishing pad. I also got a cutting pad but opted not to use that my first time out.
Having never used a PC before, and never seen one in use, I was stuck trying to remember techniques I had read. I "primed" the pad by putting a thin line around the edge and rubbing it in with my finger. Then another thin line around the edge and spread the polish around the section I was working w/ the PC off. Then turned it on at about 3 to spread the product more. Then up to 5 (briefly tried 6, but didn't like the vibrations). I made passes front to back and side to side, trying to overlap. After a few passes, the DACP started to dust up. Removed it with a MF towel and it came off really easily. Back down to SFP, then (other products) on finishing pads. Does it sound like I was using the PC correctly? Should I apply the products differently?
Pulled the car back in to the sun and still saw what I guess is marring. It's especially visible at the ends of the sun's reflection. I took other pictures after each step, but accidentally had the camera in manual mode so they didn't come out too good.
I guess that I won't get rid of the marring without a cutting pad, and that may not even be enough. Again, 8 years of being outside and only in the past 3 or 4 have I been using decent protective products, and just discovered abrasive stuff w/ my Craftsman about 2 years ago. That said, it still irks me because I know about the ugliness that is there. I guess this car will be my learning platform so I can take better care of my next car
