Getting rid of wax residue
  • Getting rid of wax residue
    Thanks to the advice of a couple of members I did the clay and three step clean, polish and wax, and the outcome is absolutely beautiful. Unfortunately, as I said in a previous thread, I am not into this as much as some of you guys, and just wanted and nice shiny black car. Soooo, I did not tape any of the molding, and as careful as I was, I have some wax residue. Not on the molding itself, just in the corners along the strip molding. How do you get this stuff off? I tried an old toothbrush in a small area, and I think I may have put a scratch in the paint. Maybe a new soft toothbrush???? Thanks, Dianne
    Re: Getting rid of wax residue
    Check out this thread...
    M3916
    M4016
    Peanut Butter Oil
    Vegtable Oil
    Toothbrush used carefully
    Next time work carefully around trim or tape it off with painters tape.
    How to tape-off a car
      Haven't tried this method personally but forum member jfelbab has been detailing cars for a long time and his posts are always very credible.
      Originally posted by jfelbab View Post
      Jist about the best tool I've found is this:
      I also have a stick eraser that looks like a pencil that is wound with a spiral of material that you remove to expose more eraser. I carve this to a sharp point with a razor blade to get into the smallest of cracks.
      The rubber grips the left over wax/polish and easily removes it with out damage to the paint/plastic.
      Easy enough to try...
        Thanks Mike. I tried the toothbrush, but not with detailer. Might go buy an new soft toothbrush with the detailer and carefully try again. I know of the pencil eraser that is like a pencil and you peel off the paper. Sounds like an excellent trick, but no clue were to find one. Haven't seen those things in years. Thanks, Dianne
          they sell a those little detail brushes at like walmart with a pointy rubber end and it works real well for me at getting in those tight areas if i get wax somewhere. Best thing its only about $1.50. Hope this helps
          Jon's Premium Auto Detailing
          210-281-8151
            Perfect!!! Thanks Derrickg. I appreciate you taking the time to take the picture.
              no problem, im glad to be of some assistance.
              210-281-8151
