G-100 Polisher Question
  • G-100 Polisher Question
    Hi eveyone,
    I just purchased and received the G-100 from Meguiar last week and it was great.
    I have a few questions for this little machine:
    1) Apply wax / polishing compound (such as Color X or NXT Techwax) - - - set speed to "3" [Y/N];
    2) Removing the wax / polishing compound - - - set speed to "4 or 5" [Y/N];
    3) In what circumstances do we use speed "6"?
    Thanks for helping and confirming.
    That sounds about right to me. I was at the detailing class this last weekend, and that is what we were shown for the application and removal setings.
      Re: G-100 Polisher Question
      Originally posted by C32 AMG
      Hi everyone,
      1) Apply wax / polishing compound (such as Color X or NXT Tech Wax) - - - set speed to "3" [Y/N];
      For applying polish or wax, products intended to add beauty, gloss and/or protection, a setting from 1.0 to 3.0 works really well.
      I tend to use terry cloth towels or microfibers by hand to remove compounds, paint cleaners and cleaner/polishes and save the bonnets for removing waxes. You can use them for removing the other products, it's personal preference.
      For removing wax, the 4.0 to 5.0 setting works well.
      Meguiar's does not recommend using the 6.0 setting for any procedure. This setting tends have a somewhat destructive force on the foam pads and will wear them out. Depending upon what product and foam pad you're using, the 6.0 setting can also be the cause of micro-marring.
      Your welcome, good luck with your projects!
      MIke
        Hey C32 AMG
        Congrats on your new purchase!! You will LOVE IT!!
        If you have any further questions about the use of it, please feel free to ask!
          The only thing that I can think of is wood sanding, as that is what the machine was designed for to begin with.
          r. b.
            Thanks guys,
            I would print a label regarding the speed of this G-100 and stick it on my tool box.
            I bought a tool box (plastic one from Home Depot) to store this G-100 (investment).
              Hey,
              I have plastic tool boxes for each of my rotaries and PC!!! I keep the dedicated backing plates with them and everything else I may need.
              Cheers!
                Originally posted by 2hotford
                Hey,
                Cheers!
                What size of the tool box would you recommend? Mine is 16" x 7" x 7".
                  I picked up an 8" x 16" x 9" plastic tool box from Sears for about $7.00 recently. It holds my PC & related hardware....Plus it has a pull out tray for wrenches, brushes, etc.
                  r. b.
                    Here is mine:
                      One quick question again, when I look at those pictures in the "Gallery", how come most people do not put that black handle on the G-100A polisher (even Mike Phillips)?
                      Is it much more easy to control the polisher?
                        Hey,
                        Some of us, including myself, do not use the handle as it gives better control and weight distribution above the pad, IMHO. I can then hold the buffer with my right hand and place my left hand on the buffer's head so I can exert the right amount of pressure on to the pad.
                        Cheers!
                          Hey,
                          Cheers!
                          We don't have to apply any pressure on the polisher right?
                          We should hold the polisher and let it do all the works or should we apply a little bit pressure at the polisher head?
                          I believe the polisher itself is weight around 5 lbs.
                            Hey,
                            When using a cleaning product like #83 DACP, I like to apply a fair amount of downward pressure on the buffer's head. The other key is to move the buffer SLOW. The above combo of speed and pressure will help the buffer to break down the product properly.
                            Now, for glazes, and Last Step Products, I use very little pressure.
                            I hope this helps!
                              Hey,
                              I hope this helps!
                              Understand.
                              Thanks.
