Detailing Question
  • Detailing Question
    Whats the point of using a quick detailer after applying your lsp? I know quite a few pro's that use final detail or fk1 425 after they put on the lsp. any reason behind this?
    Re: Detailing Question
    Quick Detailers are sometimes useful as a check step to ensure all of the wax has been removed. They also add a extra layer of gloss to the layer of wax that they just applied. In my experiences, a coat of Last Touch for example gives a much more slick "feel" to the surface of the car, and a deeper gloss versus a layer of polish followed by an LSP alone. It's not a huge difference, but it is a noticeable one.
    Having said that, with the majority, if not all of Meguiar's LSPs, the polymers take on average 24 hours to setup. After which time, a coat of a quick detailer would be more appropriate, instead of just following removal of the LSP coat. However, for reasons of practicality, this is hardly ever possible.
    Detailers also use a quick detailer to ensure they have removed any residual fingerprints left behind that they might have missed.
      Yeah, because of the interfering with waxes setting up, I generaly dont do it unless a bird comes by.
      But in addition to what was mentioned above, if a sloppy detailer used to much product, and had dust everywhere, then a wipe down wiht QD would also help solve that mess.
        I also use it between coats of wax. As they said, it helps to remove anything that you might've missed in the first round of polishing the lsp off.
        Wiseguys Auto Detailing
        Serving North Florida
