Do any of you guys regularly polish with PC or rotary out in the open? Occasionally family members (without garages) ask me to polish their cars, and I don't have a tent to tote along. Any of you guys do this regularly?
Polishing when no shelter is available...
Re: Polishing when no shelter is available...
Sure...
Shrink the size of your work area down. Borrow the shade from a nearby building. The hardest parts to work on in the open will be the horizontal surfaces as dust and contaminants in the air tend to settle on these ares and not the sides, so just do your complete process, (whatever that is), to the hood all at once, i.e. clay, the clean, the polish and wax, as soon as the wax is dried wipe the excess off and move to another horizontal panel and repeat.
You can usually do the sides more leisurely because dust isn't trying to land on these surfaces and usually the sun isn't beating down on them. You can also move the car around to position the panel you're working on isn't in direct sun.
Takes longer, but that's the way it goes...
If you're working by machine, get some extension cords so if you do find some shade you can move the car to the shade and still be able to reach it with power.
Originally posted by houndlover View PostThanks Mike. This may be a stupid question, but do any of the Meguiar's polishes do better then others in these working conditions?
Regardless, if the temps are normal, say a range of 70 degrees or within 10 degrees either way it will be like working inside, if the temps are real cold or real hot, the most product will start to become more difficult to work with usually in the wipe off but sometimes in the application. So remember this, anytime you're working in extremes, simply shrink the size of your work area down. Makes things slower, but maintains ease of application and removal. It's the trade-off for working in extremes.
You can probably pick up a decent size tent at Pep Boys for about $80. That's what I did. It actually came out to be $72.00 because it was on sale.Jesse
www.ShineTechAutoDetail.com
Facebook www.detailing.com
Shrink the size of your work area down. ... just do your complete process, (whatever that is), to the hood all at once, i.e. clay, the clean, the polish and wax....
Today I am going going to wash the whole car and then concentrate on just one wheel, tire and wheel well: rewash, clean, polish, wax just that one area. Maybe spray a detailer inside the wheel well.
Then I won't have any excuses this summer.
(Think I am going to use Gold Class for the wash, NXT for the LSP, not sure yet about what goes in between. Going to do everything by hand, to get the feel of the products.)Success is never final, failure is never fatal. It's courage that counts.
by John Wooden
'88 Honda
Found a 10'x10' for $ 99 at Home Depot last fall....bit challenging alone to put up, but practiced couple times and made it work for me.
Granted not big enough to cover 100% of some vehicles, but as Mike P said, just shrink your work area.WrightDetail
The Wright Way
2007 Chevy HHR
2008 Chevy Silverado Crew Cab 1500
