Is the technique for waxing a black car different than cars with other colors? I heard using a circular motion was not a good idea. Any thoughts would be appreciated.
Technique For Waxing Black Cars
Re: Technique For Waxing Black Cars
Unless we are talking about a single stage paint, typically we are working on a 2 stage paint job with the pigment coat on the bottom, than clear coat on the top, which means that we are working on the same type of surface, so there should be no difference.
My philosophy is that no, there is no advantage to doing it one way or another so long as you are using the proper materials.
You have a couple ideas running together.
1. Clear coat is just paint with no pigment in it. So no matter what, you are working on paint. As mentioned above, the same techniques would then apply to any paint.
2. The idea of circles vs straight lines comes from the fact that if a product is going to scratch the paint, it would look better if all the scratches were in nice neat rows. Obviously though, the better option would be to not scratch the paint. Using high quality pads to apply your products, high quality cloths/towels to remove them, and of course products that dont leave scratches means you can move in any direction you like.2017 Subaru WRX Premium - WR Blue
The "circular motion is not a good idea" line of thinking stems from people looking at swirl marks under a harsh, direct light. All the tiny scratches appear to be in a circular pattern so folks immediately assume that they are, indeed, circular. But if move the light source (or move your position if said light source is the sun - sorta tricky to move the sun on your own) you'll see that the circular pattern moves with the light source!! This should tell you that those tiny little scratches aren't actually in a circular pattern, hence applying/removing wax in a circular pattern is not the issue. Technique, tools and materials used are what matters, regardless of color or paint system.Michael Stoops
If you’re using a non-abrasive product with a high quality, clean, soft foam or microfiber applicator pad, and you’re working on a clean surface, then it shouldn't’ matter which direction you move the applicator pad over the finish because nothing you’re using will be instilling any scratches or swirls into the finish.
The above was taken from the below article which can be found in our Hot Topics
Circles or Straight Lines?
With black paint and any dark colored paints, because these colors show swirls and scratches to your eyes easier than light colors it's always vitally important that you always work clean, that means make sure the car is clean and your applicators and wiping cloths are all clean.
It's also vitally important that you always use good technique as well as include the human elements of care and passion.
Polishing paint is an art form, if you do the above you'll get great results.
Sorry for the bump, just wanted to give my thought on this.
If you're washing the car with a wash mit or claying the car, I would use a Snake Pattern wipe.
Reason being is in those steps you're still cleaning the paint from dirt and contaminants.
Once at the compounding step, polishing step, and waxing step; it shouldn't matter if you wipe in straight lines or circular motions.
Originally posted by KidDetailer View PostSorry for the bump, just wanted to give my thought on this.
If your applicator and paint is perfectly clean, it really won't matter. To me (ok, maybe I'm wrong), if the conditions aren't ideal (dirty paint or applicator), a scratch is still a scratch. The only difference is that with circular motion, you get circular scratch. If you do straight line, you'll get straight scratches (but it will be much easier to remove straight line scratches vs. circular scratches)
