I've seen a few people mention using 66 to remove swirls. I have a black car that I would like to remove as much of the swirls as I can, but I'm working with 1996 Nissan paint, which is not the best. I used Zaino in the past and it did a good job of filling in the swirls and making them disappear for a time, but it was a hassle to mix the bottles and only apply so much in a 24 hr period. Does 66 do the samething as Zaino, or is there a Meguiars product that will "fill in" swirls?
#66 questions
Re: #66 questions
M66 is the strongest of the cleaners in the Meguairs line.
there's #6, Colour-x and 66.
it is also a good choice with scratch sensitive paints.
also you know, you don't want to fill in swirls you want to remove them.
personally, i'd try.
wash
clay
M80
#66
then your choice of wax x 2.
Re: #66 questions
I'm working by machine. I've used 83 and it got rid of most of them, but I didn't have the correct amount of light, so some of them stayed. I also have some 80 and I think 82, but I would have to look.
I know I need to remove them instead of filling them, but I'm just worried I'll keep removing too much paint and damage it. My car is single stage.
Re: #66 questions
The 83 removed most, but I didn't have enough light to see the sides of the car like I needed to. I've bought a dual 500watt halogen light than I'll use this time. I was going to start my spring cleaning soon, and wanted to make sure I had everything before hand. Before I found this site last summer, I was happy if the car looked good and wasn't concerned as much with swirls. Now I don't want to drive the car when I can see them, even if 90% of the people won't notice.
Re: #66 questions
Originally posted by eric96ser View PostNow I don't want to drive the car when I can see them, even if 90% of the people won't notice.
proper lighting makes a huge difference.
slow down your arm speed with M83. it should make a difference.
it all comes down to technique in the end.
