Want to buy a pneumatic orbital sander, which do you recommend?
  • Want to buy a pneumatic orbital sander, which do you recommend?
    I am in the process of buying a pneumatic orbital sander but not sure what brand and size I should buy. Can someone give me some guidance. Thank you!
    Re: Want to buy a pneumatic orbital sander, which do you recommend?
    Hi:
    Hope you have a big compressor tank; these take a lot of air to operate.
    Regards,
    KTruck
    Make it Shine
      The one that the gang is using here is the Mirka Bulldog. Not surprisingly, it works really well with the Mirka abrasive system. (Which is a great paint sanding system!)
      It uses the industry standard backing plate so it can also be used with other systems too. In some of these pix it's using a 3M Trizact disk.
      A little wet-sanding using an air powered DA Sander
      PC.
        Get a dynabrade, They come in .5mm cut and .25mm cut. If your wanting to wet sand get the smaller. And a 15gallon 2.5hp compressor will run it, it will work alot but it will run it. You should be able to find one for under $200 at a bodyshop supply store. I use mine daily with 3m 3000 trizact paper. And if you do have to get dirty with some 1500 or 2000 paper the 3000 on a da makes it much easier to buff out the courser scratches.
          I played with a pneumatic DA once and I noticed that it turns more than the PC. It also doesn't bog down. I only played with it for about 10 mins because it was in my friends cousins shop. If I didn't already have a PC, I would want to get one of these units, because they seem a bit more powerful.
          In that pic, is Mike peeling of the interface pad? It looks awful soft.
          It looks like some people don't like the concept of waiting in line.
          Patrick Yu
          2003 Honda Accord
          2008 Honda Accord EX-L V6
            Originally posted by sneek View Post
            ...In that pic, is Mike peeling of the interface pad? It looks awful soft...
            No, that is the abrasive.
            It's a Mirka Abralon pad. The abrasive is bonded to a cloth face with a foam middle layer and loop backing. They're awesome for wetsanding, they conform closely to surface contours and the water flows freely through the cloth and foam.
            PC.
              where can i get one of these sanders!?!?!?
              www.firstclassmobiledetailing.com
                Here you go.
                Abrasives, sanding tools and polishing compounds under the same roof. When it comes to an excellent finish, we have the passion to exceed expectations.
                and here is the Bulldog Sander
