I live in a building that has a parking structure, but no electrical outlets. So I was wondering if there are any good, yet affordable, battery powered rotary buffers.
Battery powered rotary buffer
Re: Battery powered rotary buffer
The problem is generating the torque to actualy have enough power to remove defects, and then having batteries last long enough to be usefull. There are some battery powered polishers, Meguairs even had one a couple years ago, but they are ok for spreading and maybe removing wax at best.
You would get better defect removal with your hands.2017 Subaru WRX Premium - WR Blue
Originally posted by Anonincog View PostI live in a building that has a parking structure, but no electrical outlets. So I was wondering if there are any good, yet affordable, battery powered rotary buffers.''USE THE LEAST AGGRESSIVE PRODUCT TO GET THE JOB DONE RIGHT''
Sounds like a job for ScratchX. I wouldnt plan ot do it all in one day though... Do a panel or two a day, and your arms will thank you. Get a few very well worked in applications of ScratchX on the panels, then polish and wax them, and rest until the next day...
How To Remove Swirls By Hand
How to remove a defect by hand with ScratchX2017 Subaru WRX Premium - WR Blue
Heres a couple of ideas that may help you. First of all is there any way you could rent a mini storage. They usually have electric and you would be working in the shade. #2 How about a friend or relative, maybe use thier carport or garage, when done to thank them pop for pizza. Just a few ideas, hope they help.quality creates its own demand
According to this you may be able to run the PC off your car battery. Not sure how long the battery would last or how you might keep it charged...
BASIC FEATURES & OPERATION
The PC 7424 has a powerful motor for its size, yet it pulls a scant 3.7 amps at 110 volts. If you don’t have a garage, you can run the PC 7424 off of your car battery using a 750+ watt power inverter. The tool uses a standard 5/16-24 spindle, so a lot of different attachments will fit.
Originally posted by Mike Phillips View PostSince you're in Hawaii, if you arrange for our plane ticket, we'd be happy to come over and help you apply ScratchX or anything for that matter. Maybe a shady spot under a palm tree down by the beach?quality creates its own demand
