gold class or #26
  • gold class or #26
    GOld Class has brazilian yellow carnauba like 26??
    what teh difference of the 2 products??
    Re: gold class or #26
    Gold Glass is a polish and wax in one.
    26 is a resin sealent with a splash of carnuba, for lack of better terms...
    26 will last much longer (I have never gotten good durablity out of Gold Glass, at all) and looks better IMO.
      thanks for the info , and another question
      is ok if i use deep crystal cleaner paint(step 1), then #7 , and then use #26, ?? or is better if i use fine cut cleaner #2 ??
        It is perfectly ok to use DC1, #7 and #26 but it all depends on the paint correction you want to do. You can do a test spot for both the DC1 and #2 and see what result you like the best and then proceed with #7 and #26 after it. So its gonna be like this.
        1. Wash
        2. Clay if needed
        3. DC1 or #2 on a test spot and use what gives you best results.
        4. #7
        5. #26
        SYDSTER
          Ive always read that #26 is a pure carnuba...
            #26 is a pure carnuba wax. Correct me if I am wrong, but I believe that all Meguiar's waxes are mixes because a 100% carnuba wax would be impossible to apply and remove. #26 has a high content of wax compared to other products.
            Chris
            Dasher Detailing Services
              i thonk #26 and nxt are the betters wax of meguiars , i will try try both side by side to see the results
