ScratchX
  • ScratchX
    Ok... I just got my G100 ordered. I am going to be doing my entire car with the scratchX since off-roading does a mess to the paint. My question is using the new and improved SX with the G100. At what speed to I apply it with... and do I increase overtime to work it in? I saw the chart for application speeds for all the products...but SX was not listed in it.
    Also, what pad should I use? I am assuming since this is considered a cleaner I would go with the 8006?
    Re: ScratchX
    Yes, 8006 pad@ speed 5. Speed 5 for defect removal, 3 for wax application and 5 to remove wax. Those are basically the two speeds to be concerned with.
      Re: ScratchX
      Thank you
        Re: ScratchX
        Use the W-8006 on the 5.0 Speed Setting. After you work and area for at least 2 passes in 2 directions you can wipe off or try for 3 passes in 2 directions.
        After wiping the area clean inspect; if the results look good move on to the next section, if you still have swirls and scratches you want to remove then work the area a second time with a fresh application of product.
