Cleaning Foam applicator pads
  • Cleaning Foam applicator pads
    Hi all,
    I tried searching for this topic but couldn't find anything. I'm hoping someone can give advice on this...What's the best way to clean the pads and once they're clean can we use them for other meg's products? TIA for the info!
    Re: Cleaning Foam applicator pads
    1. Soak in hot water with dish soap for a half hour.
    2. Re-Soap and work it in.
    3. Rinse until clean.
    4. Dry in a terry towel.
    5. Store in a ziplock bag.
      You can soak them over night for all it matters...
      But I still try to label my zip-lock bags a bit, try and keep things seperate.
        Thanks for the replies guys...so i'm going to assume by placing them in a ziplock bag...once you've used them for one product it's best to keep using them for the same specific product right? Please correct me if i'm wrong. Thanks again!
          I use more than one product on each pad, I just make sure they are completely clean before use.
            Oh that's good to hear...I thought I'd have to go out and buy more...$2 isn't much but it can add up..heheh...I have enough for one detail day then I can clean them for the next
              If you clean the pads really well, it wont really be a problem, but I try to keep them for each seperate product.
                i use little bit of dawn dish soap and water 30 minutes or so i shake em in a small container ,then rinse them of twice real good and last hang dry them next ....works well for me
