Need some advice
  • Need some advice
    Spring has sprung and it is time to clean up the car. I have a 2005 Red Audi TT Roadster. I've used NXT is the past and liked it because it came off easliy. I don't have the time nor place for it to set up properly so I usually apply 2 coats. Question 1 is this fine? Any advice to which products I should use? Normally I would do the following: Deep Crystal
    Re: Need some advice
    One application of NXT is fine, just do a great job of applying it evenly and working it as you go. Allow it to fully dry before wiping off.
      Thanks Mike. I forgot to add the follwoing:
      I always used the following in the past: Deep Crystal
        Lets try this for a 3rd time. I have used the following steps in the past.
        Deep Crystal System Paint Cleaner, 7, 26 or two coasts of NXT. Should I be doing something different?
          I'll throw this out there, that a cleaner/wax like ColorX might be a good product for you to look at.
          1. Wash
          2. Clay
          3. ColorX
          4. Wax - Nxt or other favorite.
          Seperate steps will almost always get better results, but if you are short on time, sometimes you have to compromise something. And ColorX isnt shabby at all, believe me.
          Plus, you'll get the recomended 2 coats of wax then...
