Ultimate Bonnet
  • Ultimate Bonnet
    Can the Ultimate Bonnet be put over a foam pad?
    The Ultimate Bonnet should be put over the foam pad. Below is a picture of Mike and Greg getting ready to remove NXT Tech Wax from our 1975 Corvette Extreme Makeover.
    The Ultimate Bonnet works best when used over a Meguiar's W-7006 foam cutting pad or a W-8006 foam polishing pad . The Meguiar's W-9006 foam finishing pad can be used, but because of its extra softness, it tends to work better for applying polish and wax.
    Remember, the Ultimate Bonnet is reversible and washable.
    Check out the high gloss finish the Ultimate Bonnet left on the finish of this 1975 Corvette in the Extreme Makeover Forum
    1975 Corvette Extreme Makeover - The Importance of a Paint Cleaner
    One comment that both Greg and Mike made after using the Ultimate Bonnet for the first time was how easy it made removing the Tech Wax by taking all the work out of the procedure.
      Even more, the results after removing NXT is great. For some reason using the PC and UB to remove NXT gives the surface a noticable "pop" vice by hand.
