Cleaner Wax Question
  • Cleaner Wax Question
    Hello all,
    I have a question about the application method for Meguiar's Cleaner/Wax. If I use the G-100, do I apply it like a wax or like a cleaner? W-9006 or W-8006?
    I am assuming like a wax, speed 3, W-9006 etc...just want to make sure though...
    Thanks for any replies!!
    Re: Cleaner Wax Question
    I have never actually used this product, but I do use a lot of M66 and it is my understanding that you want to apply it the same way as a cleaner or polish (Speed 5 on the DA using an 8006 pad, slowly working it in and overlapping 50%) Once you've done this, don't wipe it off, but instead let it cure like you would a wax. (30-45 mins) and then wipe off with a MF towel. This is what I do with it and it provides excellent results.
    Good Luck.
    Dynamic Detailing
    541.668.0480
      So are you saying it has diminishing abrasives? If so, then ive been using that wax in the wrong way. I also just put it on like a wax.
      I usually use cleaner wax on my door jambs. I just did the other day actually. They never see the elements, so they do not need any special attention. They usually come out looking and feeling great.
        I am going to have to say that its more like a wax than a cleaner....you never no, but I am going to wait for some more replies. I have used it before and didn't notice a difference so I am assuming I just applied it wrong.
        Thanks for the replies!!
          Good Luck.
          I use this procedure with all waxes that have cleaners in them including NXT. However, I usually set my pc at 4. Not only do I overlap, I move my pc at right angles to previous "runs".
          Tom
            Tom
            What type of results do you achieve by using this process. I use this method when doing customers cars that just want a basic wash n wax and it almost produces results to good (it makes them feel they don't need anything more)
            Dynamic Detailing
            541.668.0480
              you can use either the w8006 or w9006 pad, but to add a little bite since it is a cleaner wax, you could use the w8006 pad on the 3 - 5 setting and work it in to a nice thin even coat, and then remove it after it has fully dried. remember... do the swipe test to indicate whether or not it is ready to remove.
