Claying did not do anything. Has anyone used 83 or 80 on glass?
Meguiars does not recommend using them on glass.
But, I and others have used #83 would good luck on water spots. Not sure it will work on sap. Give it a try and let us know how it works. Otherwise something like Goo Off might work.
give speedy 500 a try! it's made by kent industries or call 1-800-654-6333 to order. i think i give around $48.00 and worth every penny! if you've ever used goo gone to remove the glue left over after removing pin stripes or decals , it takes way to long. with speedy 500 you can remove the glue very quickly and safely. anyway just trying to help.
You Don't Know What You Can Do Until You Try '' TECHNIQUE IS EVERYTHING'' Test Hoods Are Cheap And Most Of The Time Free
