Need info on wax and polish
  • Need info on wax and polish
    My eyes are starting to bleed reading all the info on various brands of waxes and polishes. Meguiar's seems to be a good product and I just found this forum and started to read.
    I just purchased new 2006 Buick Lucerne, so I don't need to do anything fancy like claying, I just want to polish it and wax it. It is black, and while "Black cars only look good in the shade", they look pretty darn good in the sun, so I want to polish it and wax to protect the shine.
    Meguiar's has so many products I have not clue what to use. Would someone recommend which polish and wax to buy. My Turtle Wax days are over. Any other suggestions will be greatly appreciated
    Thanks for your time.
    James
    2006 Black Buick Lucerne (MY LAST BLACK VEHICLE)
    2000 Silver Buick LeSabre
    1977 White/Black Triumph TR-7
    Re: Need info on wax and polish
    James
    Hi James and welcome to MOL!!!
    you've come to the right place for help.
    First, you said that you 'just' want to polish and wax your car.
    but if you read the following link, part of the 5 step process the Meguiar's recommends is to Clay bar your paint's finish.
    in doing so you will help rid of any contaminants that will reduce the quality of your results.
    The 5-Step Paint Care Cycle.
    Step 1 Wash
    Step 2 Clean
    Step 3 Polish
    Step 4 Protect
    Step 5 Maintain
    When you clay, your are cleaning your paints surface on the top layer getting rid of any contaminants. ie. overspray, dirt, dust.
    Grab a sandwich bag, and place your hand in it. run your fingers along your paint's finish. if it isn't smooth it needs to be clayed.
    i understand you don't want to do it, but you'll achieve GREATER results by doing so. i personally clay my car everytime i wax and polish it and it helps in making it feel smooth as glass. that is the overall goal of clay process. to make your paint feel smooth as glass. after claying, if you spray water on your car, you'll notice that its as if you just applied a coat of wax.
    TRUST ME. ITS WELL WORTH IT and other guys will tell you the same.
    How to Clay Paint
    How To Clay Paint
    In terms of what products to use, there is so much to choose from.
    Is your car a daily driver?
    Do you park your car inside a garage at night?
    Do you drive through dusty area or gravel roads?
    Is your car heavily swirled or swirled at all?
    What type of results DO YOU WANT TO ACHIEVE? Show car shine?
    Will you be applying by hand or with a PC G-100? (machine polish)
    All questions you need to answer before determining your choice of products.
    For starters though, here is what you would need if applying by hand.
    Meguiars Supreme Shine Microfibres (for removing wax/polish)
    Meguiars Clay Kit
    Car Wash - NXT Soap - great choice
    Paint Cleaner - Scratch X, Colour - X, M80
    Paint Polish - Meguiars #7, High Tech Wax #26,
    Wax - NXT or wax of your choice like Gold Glass
    2 5 Gallon Buckets with Two Grit Guards
    now if you just want a cleaner/wax all in one you could go with Colour-X or Meguiars #66.
    Then your process would be.
    Wash
    Clay
    #66
    NXT x 2 (always two coats to get a nice uniform layer of protection)
    you could also do the following. its a really good system for the consumer with good results.
    Wash
    Clay
    Deep Crystal #1
    Deep Crystal #2
    Wax of your choice X 2
    Deep Crystal Paint Cleaner
    Its so hard to suggest products to you without knowing what you want to achieve.
    If you were doing this all by machine your products will be different.
    please help us out by telling us what you want to achieve.
    here are some more links for you to read.
    How to Remove Swirls by Hand
    How To Remove Swirls By Hand
    How to Wash Your Car Using the Two Bucket Method
    How To Wash Your Car using the Two Bucket
    Method
    The Swipe Test
    How to tell when a Meguiar's wax is ready to remove - The Swipe Test
    Suggested Products for Taking Care of a New Car
    What are the Differences Between Meguiar's Waxes?
      I agree with what TrufflePig said.
      But, If that just sounds like more than you want to do. Pick up a bottle of NXT wax and have at it. It will look great. If you decide you want something that looks better, then you can always add steps too.
      All I used to do to my black ride was NXT wax. It looked great. But I wanted a little more shine and a little more depth and a little more... Well, here I am now with more products than I care to admit.
      It is all about what your expectations are.
      Scott
        Thanks TrufflePig for your reply.
        I wrote "just" because the car is new. I don't need to clay, or remove swirl marks, or clean the paint. "Just" polish and wax.
        All the numbers #21, 22, etc. are just confusing me. Which one (s) for a new car. Car is new but a 2006.
        Thanks.
          Just in case you didn't see this yet, it is a huge help... Meguiars Online Acronyms
          Scott
            Geez, I really thought this would be an easy question, with an easy answer.
            Thanks BlueZero, I had already viewed the post for the Acronyms. What I concluded from that post was I can use the following:
            #5, #6, #7, #8, #10, #12, #20, #21, #26, #50, #80, #82, #83, #87, #88,
            ASD, DC#1, DC#2, DC#3 and probably half a dozen other #s.
            All I wanted was a recommendation on which one for a polish and which one for a wax. I am not showing the car, I don't need every one of the products Meguir's has to offer, just just some decent polish and wax.
            Perhaps I should try Adams or Mothers for an answer. ****, maybe someone even at Turtle Wax can give me a simple answer.
              Pick up a bottle of Gold Class Car Wash and a bottle of NXT Tech Wax and some quality microfiber polishing cloths and this will be a good start.
              You'll also want a quality wash mitt and some quality drying towels so you don't put scratches into the paint while washing and drying. Meguiar's offers these and you should be able to find these at most auto parts stores.
                Perfect, THANK YOU. That was all I needed.
                  just because your car is new doesn't mean it won't have anything that is potentially contaminating the finish.
                  it can get dust from its travels, spray from when on the trailer and being delievered.
                  you'd be amazed. try it out. clay the finish and let us know how it went.
                  and if it turns out to be CLEAN AS, then you do it anyways and better safe than sorry.
                    Thanks again TruffelPig. (Love that ID) You might be right, but the paint feels smooth. Anyway, not sure I am into claying or other heavy duty detailing. Did lots in my youth though.
                    I am just an 'ole' fart with a new car and want something a little easier to apply and that looks good. Don't want to die in my garage working up a sweat.
                    Rather work up a sweat with Elizabeth Hurley.
                      You might be interested in something like ColorX then, which is a great cleaner/wax. I use ColorX topped with #21 Synthetic Sealant quite often for a fast detail.
                        i reckon most of us would love to work up a sweat with Elizabeth hurley.
                        regardless, a GREAT shine starts with an AWESOME WASH. and the clay process is part of it. i'm so for the clay process its not funny.
                        but maybe you can just do the claying when its really needed.
                        but yes.
                        Wash
                        Colour-X
                        NXT
                        or
                        M21
                        that would be a sweet, slick look. Murr mentioned it and it'll look nice.
                          Murr and TrufflePig already said it, but wanted to say it again.
                          Wash
                          ColorX
                          NXT, M21, or M26
                          It'll help leave a good base to your with some pretty good depth along with the protection of wax.
                          I haven't used colorX so I'm not sure exactly how it is used, but I do use what I'm pretty sure is Meguiars Professional Line counterpart M66 Quick Detailer. A little trick to make sure that you get the most out of your work would be to let ColorX cure for 30-45 min after applying it (like a wax) (that is if it works like M66) and then apply your favorite wax over top so that your getting meguiars recommended two coats of wax. I'm sure someone with experience using ColorX will chime in and correct me if I'm wrong or reinforce it if I was right.
                          Don't give up hope with all the information and how it can be kind of confusing though. I felt the same way when I first started browsing through here, but trust me, I've learned so much off of hear in just a matter of a couple months, and the more you learn, the more everything else makes sense. (and hopefully down the road you'll be as passionate at claying your car as much as TrufflePig is)
                          BTW, first time I clayed my car I was so amazed that I'll never go back. Never thought it could produce those kinds of results.
                          Dynamic Detailing
                          541.668.0480
                            Wash
                            ColorX
                            NXT, M21, or M26
                            i swear man, i live by that. when i leave my part time job gig, i usually park at the back, my car is parked next to another car (co-workers) of the same colour, and only mine SHINES like you wouldn't believe. and everytime, he (co-worker) makes a comment about my car and its shine. a great wash goes a long way to a great shine.
