How does Hyper Wash compare with Gold Class/NXT/Shampoo Plus?
  • How does Hyper Wash compare with Gold Class/NXT/Shampoo Plus?
    hi all,
    could anyone give me some input on how Hyper Wash is like?
    For it's 400:1 dilution ratio, it seems to be the cheapest shampoo Meguiar's makes, yet, not many people use it...
    I wash a few cars at home and it hurts my wallet to wash with NXT, so I was thinking of switching to Hyper Wash.
    as per title, how will Hyper Wash compare to NXT/GC/Shampoo Plus?
    Is it as slick?
    Does it rinse of as easy?
    Does the suds stay throughout the wash?
    Is it gentle on waxes?
    appreciate any comments, thanks!
    Re: How does Hyper Wash compare with Gold Class/NXT/Shampoo Plus?
    Little problem in here: I have not used any at all but still can answer some questions
    Is it as slick?
    yes it should be
    yes, just make sure you don't use too much soap or it can be a little harder to rinse
    they should, since it's Meguiars' most concentrated car wash
    count on that
    Hope this helps
    " Sometimes logic is your friend (Mike-In-Orange)"
      thanks chex...
      I may get the Hyper Wash soon, but somehow still not convinced..since the cost per wash is so cheap..not many people rave about it.. hmm
      again, thanks, I appreciate you input
        Hi Ken,
        I have both but like Shampoo Plus as it's so easy to use as opposed to Hyper Wash which because it's so thick means it can be difficult to mix properly especially when it's cold.
        One point.......always remember to stick to the dilution rates stated as using too much can cause smearing when it comes to waxing.........that said I have reduced the stated dilution rate and only use 80 to 90ml per application for the above reason and add the other 30ml to the rinse bucket.
        As far as suds is concerned........I have never been a fan of suds for this reason "when you have lots of suds they tend to bail out of the bucket so your loosing some of the libricity" I prefer not too much suds but you can get as much as you want it all depends on how full the bucket is and how strong the flow of water is going into the bucket and they will easily last the as long as it takes you to wash your car.
        Hope that helps
        Bryan
          I was also a little curious about Hyper Wash, I am wanting to buy it for my business as it definitely does seem as if it is the cheapest option and sounds like it still performs well, especially for the price.
          I am somewhat confused just how you would make sure to dilute it to the right amound since 400:1 is such an amazing dilution ratio. Does it come with some type of device to make this process easier, thanks for any input.
          Dynamic Detailing
          541.668.0480
            Bryan,
            THANK YOU! well, I too don't really bother much about the suds but more concerned about the lubricity. I'm currently using Turtle Wax Platinum Ultra Gloss Car Wash & Conditioner, the lubricity is okay, but kinda dies after washing 1- panels, and I have to beat it with my hand to bring back the suds and lubricity, which wastes alot of time.
            How do you find the lubricity of Hyper Wash? does it stay through out the wash?...
            so the only benefit of usnig shampoo plus over Hyper wash is because it is easier to be diluted?
            jarred767,
            from what I've read, it comes with a hand pump that dispenses about one ounce of the concentrated Hyper Wash..
              Hi guys,
              Yes my Hyper Wash came with a "pump" dispenser that will give 90ml max per operation.
              Hyper does indeed stay "frothy" and have good lubricity thoughout your wash.
              Also as far as prefering one over the other is concerned........ it's mostly down to personal choice however I do think Shampoo Plus gives slihjtly more lubricity and or suds if that's what you like and leaves a very nice finish, now that's not to say Hyper Wash doesn't.
              Bryan
                Thanks for the info guys, I think I'm gonna go forward and get this product, seems like a good enough product to get the job done and definitely the best on the pocket over a period of time. I'll let you know what I think about it once I've used it.
                Dynamic Detailing
                541.668.0480
                  Hi Guys,
                  Just checked the prices listed at the Meguiar
                  2004 Toyota Tundra Limited V8 Dark Met. Green
                    Hi Guys,
                      Im assuming neither Hyper Wash nor Shampoo plus strip wax correct? Would make a great car wash for a side detailer that has clients that want weekly car washes.
                      2005 Toyota Camry LE Phantom Grey Pearl
                      2001 Toyota Corolla LE Silverstream Opalescent
                      1996 Lexus ES300 Ruby Pearl
                        All of the Meguiars washes are safe for waxes.
                          Sorry Guys - For some reason the last two posts did not go through.
                          In a nut shell, Hyper is $24.99 a gallon and dilutes 400 to 1 which is 1 ounce of product to just a fraction over 3 gallons of water. 128 ounces per gallon makes this product $0.195 an ounce and $0.195 per wash
                          Gold Class is 128 to one. Cost per gallon is $11.90. Cost per ounce is $0.093 but it takes 3 ounces in 3 gallons of water, $0.276 per wash.
                          NXT is 128 to one. Cost per gallon (2 two quart bottles) is $15.18. Cost per ounce is $0.119 and it also takes three ounces in 3 gallons of water, $0.357 per wash.
                          Really not a lot of savings for the average person but for the Pro the savings will add up quickly.
                          Hope this helps.
                            Hope this helps.
                            Thats some very good info vita, but is Shampoo plus or Hyper better than NXT or Gold Class(In anyones opinion)?
                              I think Nxt is probably the best cleaner. Shampoo Plus seemed closer to Gold Class, but I dont know about it being better at anything specific. I used #62 once so far, that might beat out Gold Class for good looks.
