Might get a G-100. Which of my consumer line products can I still use?
  • Might get a G-100. Which of my consumer line products can I still use?
    I'm considering getting a G-100, but I just purchased some consumer line products. Which ones (if any) would I be able to use w/ the G-100, & if I can't use it, what would be a comparable product to use w/ the G-100?
    Here's what I have:
    Deep Crystal System Paint Cleaner
    Deep Crystal System Polish
    NXT Tech Wax (liquid)
    NXT Speed Wax
    ColorX
    Meguiars Cleaner Wax
    Thanks for the help.
    -Ryan
    "All the sweetest winds they blow across the South." - Ryan Adams
    Re: Might get a G-100. Which of my consumer line products can I still use?
    You can use all of these products with the G100
    If you have swirls to remove you can try our new ScratchX which will be more aggressive than the Deep Crystal Paint cleaner, or try the ColorX which you already have which is also more aggressive than the Deep Crystal Paint cleaner but still completely safe for machine use.
    Deep Crystal Paint Cleaner is pretty gentle to the finish.
      Well the speed wax is for spraying on by hand nice and quick, wouldnt be used by PC.
        Mike, thanks for the reply.
        Wow, that really surprises me.
        Do the Professional line Products work better or are more effective when using the G-100 than the Consumer products?
        Thanks again for your help.
        -Ryan
          The Consumer Products are generaly meant to break down by hand, so a machine can break them down faster. This may lead to shorter working times, or the product drying and gumming up a bit.
          Some people find it happens, a lot get them to work fine...
            Murr,
            Any suggestions to keep the products from "gumming up or drying quicker"?
            And, in looking at what I currently, do you have any suggestions as to products that would give similar results, but might perform better w/ the G-100?
            Thanks for your comments.
              Dont look at the gumming up as something to be worried about, that is if it happens, you arent going to do damage or anything, so give them a try. Just stop and add more product change your method a little.
              Dont start trying to add extra pressure, since as Mike said, the products are mild anyway. Pay attention ot the size of your work area, dont go to big. A hot surface definaelty wont help. Just the usual stuff, but its easy to get excited and try and do to much.
              #80 is the go-to product with the PC for general cleaning, though if you are interested in staying as mild as possible, #9/#82 are products you could use.
                Murr,
                Thanks for the comments & for that link.
                Very helpful.
                -Ryan
                  The Consumer Line of products are formulated for a wide spectrum of application methods by a wide spectrum of people with different levels of skills and experience. Doesn't really have anything to do with the rate of which diminishing abrasive break down and many of the Consumer line paint products don't contain any diminishing abrasives, just the paint cleaners and the cleaner/waxes.
                  Working time, or play time is normal to the product, it's relative, not comparative.
                    Gumming up should never be a problem with any product, when it is, it's a sign that you've used too much product and worked it too long till it's drying up on you and the more common problem is you're not cleaning your pad often enough or effectively enough.
                      Mike,
                      What's the most effective & safest way(for the pad) to clean your pads?
                      Is it different depending on which type your cleaning: G-100 pads & bonnets, hi tech app., even coat app, etc..?
