Comparison of Meguiars to Presta
  • Comparison of Meguiars to Presta
    Has anyone here had the opportunity, like myself, to compare Meguiars diamond Cut to Presta's Ultra Cutting Creme? If so what is your experience?
    Re: Comparison of Meguiars to Presta
    I haven't used M85 nor presta, but Meguiar's has the diminishing abrasive technology which really comes handy when you have to polish.
    I use M84 compound power cleaner and I love it! When I use it with my 3M foam compounding pad, it cuts magic and polishing out the swirls is pretty easy.
    what benefits did you see with the presta compound compared to diamond cut?
    " Sometimes logic is your friend (Mike-In-Orange)"
      It is mainly the clean up of any over spray of compound after rotary buffing a section of panel. I always clean up any overspray of compound as soon as I've finished buffing. I have found that the diamond cut virtually immediately sticks to the surface & is difficult to remove but the Presta doesn't stick to the surface & is easy to remove.
      I have also found the Presta cuts better than diamond cut.
