Last Touch dilution?
  • Last Touch dilution?
    Hello all,
    I am a little confused on the dilution of Last Touch Spray Detailer. On the announcement for the new detailer line http://meguiarsonline.com/forums/showthread.php?t=2131 it says ready to use dilute 1:1 for claying, but on ADS is says that its a concentrate. So what I am wondering is what would be the dilution rate to make it like quick detailer, is it still 1:1 or something else like 4:1?
    Does that make sense?
    Thanks in advance
    Re: Last Touch dilution?
    For a quick detailer it's ready to use. If you want to use if for claying, then mix it at 1:1. It's too slick for claying with out dilution.
    Scott
      Okay thanks. Have you used the product before? If so do you think it is as good or better than Quik Detailer?
      Thanks for the reponse
        I like Last Touch. I like how it smells also.
        I tend to use Last Touch more because I have more of it.
        But both LT and quik detailer is great.
          I've only used Quik Detailer once. And after the first time I used Last Touch, I went and bought a gallon of it. I really like. As MTBPATH said, the smell is great also. I find myself just spraying it in the air sometimes for a air freshener in the garage.
          Scott
            Jumping in... I use Last Touch as well great product IMO better than Quik Detailer, I like the idea of diluting for claying and yes the smell is great!
            With Last Touch you will find it is very slick and you will get a better looking surface over the consumer Quik Detailer... LT seems to add too the over all look. Last Touch seems a little more 'picky' and streak so, for best results apply it to a cool surface in the shade and a little goes a long ways keep that in mind when using it and you will be set!
            Brandon
            2007 Black Chevy Avalanche
            My Albums: Avalanche
              Thanks for the responses, looks like I'll be adding this to my order from ADS
                Im definitely picking up a gallon of this its worth the price. Also Im gonna pick up a tin of the mild detailing clay.
                02 Ford F250 Super Duty
                International T444E 7.3L Diesel
                Not exactly stock...laundry list of mods.
                Straight Piped
                PHP FU chip
                  I cut it down 4-1 to use it as a q/d and 1-1 as a clay lube and ive had no problems.I really like last touch alot and the smell is very tropical.A gallon goes along way and is a great deal for the price.I will never be without it.
                  RZ AutoDetailing
                  My Gallery
