Need help with #80 &83
  • Need help with #80 &83
    Well i have a carbon fiber hood that has been beaten up really bad with the weather and just tried using #83 and then 80 and my hood still looks the same. With my DA what speed should i use and how fast should i move it and also how much product should i use. thanks
    Re: Need help with #80 &83
    Do you have the DVD or have you seen it? It explains how to use the D/A polisher very well.
    02 Ford F250 Super Duty
    International T444E 7.3L Diesel
    Not exactly stock...laundry list of mods.
    Straight Piped
    PHP FU chip
      The DVD is great and if you don't have it, you should get a copy. In the meantime, try this thread...
      How to use the G-100 to remove swirls
      Hope this helps...
      "No man is so foolish but he may sometimes give another good counsel, and no man so wise that he may not easily err if he takes no other counsel than his own. He that is taught only by himself has a fool for a master." --Hunter S. Thompson
        In addition to the info posted above....
        If you haven't already you might search MOL for 'carbon fiber' there are a few other that have posted some results and such. Just a thought.
        Brandon
        2007 Black Chevy Avalanche
        My Albums: Avalanche
          Well i have watch the video now and thanks for the advice that you all gave.
            Use just the #83 until you are satisfied with the results. You may or may not even need to follow up with the #80.
            If the #83 didn't get the job done, then your use of #80 was a wasted effort. It didn't hurt anything, but didn't do much toward correcting your problems. If you decide to use something more aggressive, be sure it can be used with the DA. Some products don't work well with a DA. A Meguiar's product will have that information on the bottle.
            FWIW, flaws that take 30 minutes to remove with a DA would probably be removed in 5 minutes with a rotary in the hands of someone that is good with it. You might want to consider having a pro take shot at it and you take care of the rest of the vehicle.
            Charles
            The Rainmaker
