2 Q's about detailing F250
  • 2 Q's about detailing F250
    Had a guy call today wanting his 2002 F-250 Crew Cab detailed.
    Since I've never detailed a diesel engine before, I thought I'd ask about it. Anything in particular to look out for or is it just like any other engine - Super Degreaser/Hyper Dressing.
    Also, he said something about the interior vinyl door panel looks like bleach or something was spilled on it to stain/remove the color in spots. I told him there's probably nothing that can be done, but I'd research it. Can any type of dye be used? Or does he buy a new door panel if he can't live with it?
    Thanks and Happy New Year!
    Jonathan
    Re: 2 Q's about detailing F250
    Those two products and a little passion behind any brushes you use
    Jonathan
    There are some dying options on the market, off-hand, we have no experience with them so you'll need to research them first.
    The big picture when it comes to this detail job is to look at the bleached area and if it truly is bleached white, simply tell the owner that their may be a way to make it look better, but that would be another day, and another charge as it's an art unto itself.
    Tell him what your charge is for detailing the truck as in your normal detail services, then if the customer wants the door panel fixed, you'd be happy to look into it on another day, another charge.
    Chances are good the owner will have you do the normal detail job, and he won't be let down if the door panel isn't fixed because you are not going to give him those expectations.
    It's only honest to break-up the work into components because you could spend an entire day on that door panel and still not get it right and you're customer will be disappointed.
    The truth is, this kind of work is hard and filled with risk. It's enough work just to detail a F250 Crew Cab let alone to stop everything you're doing and focus on a door panel.
    Another day, another charge.
    If it's really that important to your customer, they'll say okay and you can set a date and a charge to tackle just the door panel.
    Chances are very good, they'll tell you to forget about it because once they find out they're going to pay for just the work done on this small area that they probably understand is a hard repair to make, let alone make look good, they are not going to want to spend their money on it.
      Thanks for the wisdom Mike.
      I already told him that I would look at it and then have to research it for another time. Since I used to install car audio systems, removing that door panel and replacing it would be quick work. I don't know that he'll want to spend the money on a new door panel if that's what's needed though.
      I'll begin looking at some dye/repair options so I'll have an idea about that too.
      Jonathan
