A few weeks ago, I cleaned my car up for the winter, and it looked good in the garage. Once it was outside, I noticed 2 panels still had swirls on them, and these 2 had been repainted a few years ago, and were cleared, while the rest of the car is single stage black. After washing the car this weekend, I noticed holograms all over the side panels of the car. What causes holograms?
Holograms, what causes them?
Re: Holograms, what causes them?
Originally posted by eric96ser View PostNo rotary, just a PC 7424
That goes against the norm but it is possible. It's probably a good idea we make sure were talking about the same thing...
If the swirls show up in some type of pattern or zig-zag shape like the swirls you see below, then these were caused by a rotary buffer.
I'm sorry for the confusion. The panels were painted 6 years ago, and I'm sure they used a rotary on them. I mentioned the repainted panels, since they were cleared and the rest of the car is single stage, and the cleared panels are the ones I'm having the most trouble from. If holograms are mainly caused by rotary buffers, then I guess I still have plain old swirls.
Originally posted by eric96ser View PostI'm sorry for the confusion. The panels were painted 6 years ago, and I'm sure they used a rotary on them. I mentioned the repainted panels, since they were cleared and the rest of the car is single stage, and the cleared panels are the ones I'm having the most trouble from.
And this all goes back to paint hardness, something this forum has been doing our best to educate people on since going live in 2004. We can remember reading posts on Corvetteforum by guy always talking about how soft the paint on newer Corvettes are when the truth is the paint is as hard as glass but very scratch-sensitive, a term Barry coined in the early 1990's to describe the issue frustrating both enthusiasts and professionals as we switched over from single stage paints to clear coat paints.
The problem with the swirls in your car's cleared panels is in most cases an easy fix if you use the right products and the right techniques to correct or remove the swirls. We can show you how to do this by hand or machine, your choice.
Two examples:
By hand
Before
After
By Machine
Before
After
Let us know how you want to work, by hand or machine and we'll share with you the products and techniques to remove the swirls and create a uniform appearance over your entire car.
Either one works. I had been using the PC with 8006 pads with a combo of 83, 80, 26 then NXT. Since it's dark by the time I get home, I was working in the garage with just shop lights. The car looks great under those lights, but sunlight shows the real picture. Thanks for the help Mike.
In most cases, M83 and/or M80 will remove the swirls in most paints. In the Lexus above, we used M80 Speed Glaze. If you're not getting good results so far, then try working a smaller section, try about a 16" square section and moving the polisher slowly over the paint, (not quickly), and make 3 passes, in two different direction, (front to back and side to side), then wipe-off and move to a new section.
When you've finished apply a wax of your choice.
Take a read through this,
Will do. My last question (for today), is what is the best way, or the way you like, to put the product on the pad? I've seen some sites show a cross pattern, while others show a few dots to distribute it evenly. I don't think I've seen a post on what the best way is. I want to make sure not to use too much, or not enough.
