Help me find right sprayer
  • Help me find right sprayer
    I am seriously considering getting myself a sprayer, not a regular bottle one, but one of those that have wand, like hand held garden sprayers are.
    I am thinking about using it to apply cleaners and dressings in hard to reach (for me) areas like nooks and crannies of the engine bay or wheel well areas.
    Things I would appreciate input on are:
    1) Am I right that one gallon capacity is max I would need? I am trying to make it easy to handle around and easy on my back.
    2) I think low pressure is all I need as long as fluids are atomized into consistent fine enough mist. I have heard that might not be the case. Do you feel hand pump based units will be sufficient for fine / very fine atomization of fluids in consistent manner I have in mind or I need something stronger like battery or 12v based unit? I am trying to avoid battery based units if possible to avoid added weight, added cost, and impact on environment.
    3) If something stronger is needed for atomization what should I go with?
    4) Are you aware of any adequate sprayer that at the same time has at least fine narrow spraying pattern (hopefully adjustable width/pattern), long line, long flexible wand, and adjustable rotating tip?
    Thank you in advance for your assistance and maybe even a pointer to product with these features!
    Re: Help me find right sprayer
    Not sure of the best one, but any of the sprayers offered at a gardening store should suffice.
      I've always used a 1600psi electric pressure washer from Home Depot. Of course you have to use the wand to make the stream turn into a fan spray so you don't blow the paint off your car, but with some care, you'll never have any issues.
      Works GREAT on wheels also. Brake dust = bye bye!!!!
      It also uses far less water than your regular hose and has a bottle for soap built into the main unit so you can spray a nice coating of your favorite car soap all over before you put in a little elbow grease to get the remaining dirt off your car.
      In addition, it has about a million other uses around the house. Cleaning decks, bricks, siding, roof drains, walkways, etc.
      2007 Sprint Blue Pearl Effect Audi A4 2.0T
      Neuspeed springs, Neuspeed exhaust, Oettinger Chip
