Well I am shopping with my prize money. Have not used 81 and plan on getting it. Do I use the PC or use my hand. And which pad 8006 or 9006
Using # 81 Hand Polish
Re: Using # 81 Hand Polish
I use #81 all the time and have been very happy with it. You can use it via PC I usually set the speed at 3-3.5 and I like to use with a W9006. Don't forget to remove it wet.Brandon
2007 Black Chevy Avalanche
My Albums: Avalanche
You can use #81 either with a PC or by hand. This product is much like #7. Apply and work in a bit then remove. I do a panel at a time with either product. Leaves a very wet appearance. #81 is a tad easier to remove especially in humid conditions.Jim
My Gallery
Originally posted by kellyinkc View PostThanks guy's. It is very humid here in the summer so thats good to know. Been shopping and drooling!
The humidity factor might be one reason I like it over #7, I guess I have been very satisfied with #81 and found no reason to change. Applies and removes very easy, keep clean towels on hand to make removal the easiest.Brandon
I use it after #80... I too was thinking about getting a bottle of #82 this spring to play around with.Brandon
