after a long thought and that exams are over i think i will get the pex270 since i dont really need the power of the pex400 and i wanted to get some megs pads.
however the 270 has a 125mm backing but the megs pads are 8" big
would it matter?
also i only want to use it for just a light cut and just a finishing off a car, so which pad should i get?
i think im gonna get these 2:
Softbuff Foam Finishing Pad
Luxurious foam pampers the finish to create flawless high gloss. 8 inch diameter. Velcro backed for quick and easy attachment to W65A and rotary buffer.
Softbuff Foam Polishing Pad
Active polishing action removes minor surface imperfections and restores high gloss. 8 inch diameter. Velcro backed for quick and easy attachment to W65A and rotary buffer.
they also have:
Softbuff Foam Cutting Pad
Heavy cutting action without leaving swirl marks created by wool pads. 8 inch diameter. Velcro backed for quick and easy attachment to W65A and rotary buffer.
Cut ' N Shine Wool PadAggressive cutting action to remove serious paint imperfections. 8 inch diameter. Velcro backed for quick and easy attachment to W65A and rotary buffer.
which product should i use witht eh finishing pad and the polishing pad? at the moment the only products wax related i have is NXT wax should i get this?
Deep Crystal Polish TWO STEP SYSTEM
If you're a die hard enthusiast with a dark coloured car, go for the individual polish and wax process. It's more work but the depth of colour and gloss are absolutely incredible. DEEP CRYSTAL POLISH. Super rich polishing cream that creates incredible depth of colour.
A2116 473mL
Deep Crystal Wax TWO STEP SYSTEM
If you're a die hard enthusiast with a dark coloured car, go for the individual polish and wax process. It's more work but the depth of colour and gloss are absolutely incredible. DEEP CRYSTAL WAX. Combines premium carnauba wax with an exotic blend of nutrients & conditioners which provide a high beading surface and long lasting shine.
or should i get from their mirror glaze collection?
Speed Glaze
Speed Glaze provides paint shop safe protection. Removes light to moderate swirls, oxidation and paint defects. Restores a glistening “new paint” shine. Versatile – can be used with a rotary buffer (wool or foam pad), D/A polisher, orbital or by hand. Easy, low dusting wipe-off.
M8032 945mL
Swirl Remover 2.0
Swirl Remover 2.0 is a deep gloss cleaner/polish. It removes fine scratches and swirl marks, while providing a dark, dramatic shine. Formulated to reduce splatter and make application and wipe-down easier.
M0916 473mL
Fine Cut Cleaner
Fine-Cut Cleaner is a mildly abrasive cleaner that removes fine surface defects including light oxidation, stains, scratches, swirls and fresh water spots. Diminishing Abrasives™ cut quickly, then reduce to a polishing rouge, while Buffered Abrasive™ action lubricates the finish to prevent scratching.
M0216 473mL
Medium Cut Cleaner
Medium-Cut Cleaner is a moderately abrasive cleaner that removes medium defects, including swirls, water spots and water sanding marks. Diminishing Abrasives™ cut quickly, then reduce to a polishing rouge, while Buffered Abrasive™ action lubricates the finish to prevent scratching.
M0116 473mL
would it matter?
they also have:
A2116 473mL
M8032 945mL
M0916 473mL
M0216 473mL
M0116 473mL
