Color X & NXT
  • Color X & NXT
    There are too many discussions regarding these 2 waxes.
    However, I would like to know do I need to apply the Color X and NXT techwax together after each car wash?
    Note: Color X & NXT combinations are the best partners which I have read in the discussion forums in order to produce the brillant shine.
    Recently, I used these 2 products, the paint surface was as smooth and clean as my "Ex-girlfriend" face.
    Hi C32 AMG,
    ColorX and NXT are a killer combination, best of all they are easy to use, easy to find and excellent value for your dollar.
    You don't have to use ColorX each time however. Most people that are using the ColorX/Tech Wax combo are using the ColorX as their paint cleaner to get the paint really clean. ColorX not only does this, but it also polishes at the same time. This mean is adds richness to the paint.
    Meguiar's always teaches to Evaluate the Surface in order to determine which steps to follow for any detailing process.
    After washing, inspect the surface both visually and physically. If the car needs to be clayed, then clay it before using a paint cleaner.
    If you have previously clayed your car's finish, applied ColorX and followed that with Tech Wax, in the future, you should be able to wash your car, inspect for bonded contaminants, (they can build up in a day or two if the car is parked outside), and then go right to the NXT Tech Wax.
    Hope this helps...
