Water marks on windscreen and windows.
  • Water marks on windscreen and windows.
    I cant effectively remove water mark on my glass by washing alone. What is the besrt solution ? Can NXT Glass cleaner effectively and easily do the job?
    Is not how you shine your car, Is what you shine your car with
    Re: Water marks on windscreen and windows.
    Maybe, maybe not.
    It is the best place to start, since you will want a glass cleaner anyway.
    If that doesnt work, try claying. Claying worked for me.
    It gets a little tricky after that.
      you can also try steel wool.
      Matt
      2007 Lexus RX350
      1998 Acura Integra
        Won't that scratch the glass...?!??!
        Alex
        Mandarina Racing
          Try the PC on speed 5 ........it works a treat
          Bryan
            Steel wool did nothing for me.. I just used glass cleaner with it?? Im going to try vinegar next..
              Vinegar worked great for me! Mixed it about 1:1 with water. Guess you could use it straight too.
              Scott
                Im going straight up! Heck with this diluting, Im ready to remove the spots!
                  umm... scratchX! It has enough 'bite' to remove water spots safely.
                  You left out licking the water off. Oh, wait a minute, that's my cat, not my car. Uh, I mean my cat licks himself dry. I don't lick my cat dry. Or my car. -PC.
                    Maybe u can use DC1 and try. But Vincent over here in Pg. The detailing shop at PISA does water mark removal. They charge RM90 for the job. I think its for all the windows. Since using the rubbing compound onto my glass, it did remove 90% of the water "spots" but when it rains it does still have some water "marks" left. I even use a glass polish on the glass. Since the rubbing compound do leave some very-very fine swirls like effect on my glass. I don't dare to use it again. Hehehe. So this weekend I'll be trying DC1. Let you know how it turns out. I did think of using ScratchX but I try DC1 first.
                      I have used the DA with 83 on tough spots.
                      Meguiars does not recommend this but it works
                      http://iceburgh66.tripod.com/sig6.jpg
                        The best approach to removing water spots is to purchase a "water spot remover" from your detail chemical supplier and use according to the manufacturer's instructions.
                        There is a chemical for just about every detail application you are confronted with.
                        Regards
                        Bud Abraham
                          i've used clay with good results...
                            i think their price is at the high side, too expensive for that kinda of service..Dont you think so Bernard ?
                              Yup i do. Tht's why I prefer to DIY. I'm gonna try DC1 Sunday (tomolo) on my windscreen. I'll let u know how it goes k. Have u try the G30 compound u teach me one yet? Actually I use the cutting compound quite ok. Clear much of it.
