cleaning paint
  • cleaning paint
    Hi, I would like to know where cleanng the paint comes into play.
    Is there a need to clean the paint after claying the car? Isan't it the same thing? Thanks.
    Re: cleaning paint
    Claying takes away above contaminants and a paint cleaner takes away stuff in the paint. I use a paint cleaner regularly and when I clay I don't get much dirt on it. My guess is a good paint cleaner removes some above surface dirt also, but I am not sure. There is of course the 5 step system, do a search and u will find more info on that.
    Have a good weekend
      Re: cleaning paint
      Here is a link to the Meguiar's 5-Step Paint Care Cycle, that should help you out.
      Adding to what Mark2 posted... you want to use a paint cleaner after clay and yes it removes below surface paint defects such as swirls/fine scratches/etches and so on. As for is there a need? Well, you have to look at the surface of your vehicle and if there are some fine scratches swirls and so on that you want to remove its a needed step.
      Brandon
      2007 Black Chevy Avalanche
      My Albums: Avalanche
        Re: cleaning paint
        So when you clay the car you actually have one step more so 6 steps right?
        and it should be like:
        1.wash
        2.claying
        3.cleaning
        4.polishing
        5.waxing
        6.maintaning
        Please correct me if i am wrong.
        Cars:
        BMW e60 530
        Toyota Yaris
          Re: cleaning paint
          Well, Meguiars lumps claying and cleaning into the same step, and you would have 7 for that matter if you counted 2 coats ofwax. But yes, your overall list there looks correct.
          Remember maintaining would be a step after future washes, in between your more complete details.
            Re: cleaning paint
            Is it essential that you use QD right after waxing the car?
            Yes maintaning is more of a long term thing that you do.
            Cars:
            BMW e60 530
            Toyota Yaris
              Re: cleaning paint
              No, no QDing after waxing.
              Unless a bird uses your car as target practice, you want to try not to QD at all for 12 hours or so.
