HELP!! swirl marks on black Z-71 Tahoe
I need advise and help on how and what product to use to get swirl marks off my new tahoeZ. They can't be seen unless the sun hits the paint just right but it is noticable then. I don't own a buffer and nor do i know how to properly use one but i would greatly appreciate if someone could give me advise soon b4 winter hits. PLEASE HELP!!! Thanks
Tags: None
Re: HELP!! swirl marks on black Z-71 Tahoe
Here are soem starter links:
Step 1 Wash
Step 2 Clean
Step 3 Polish
Step 4 Protect
Step 5 Maintain
My honest answer is don't worry about it, and save up for a G-100 buffer over winter. Here are some links about it:
But, if you really want to, you will want to use ScratchX, and a lot of passion and effort. Here are the links for how to use it properly.
How To Remove Swirls By Hand
How to remove a defect by hand with ScratchX2017 Subaru WRX Premium - WR Blue
Originally posted by xjtoms View PostI need advise and help on how and what product to use to get swirl marks off my new tahoeZ. They can't be seen unless the sun hits the paint just right but it is noticable then. I don't own a buffer and nor do i know how to properly use one but i would greatly appreciate if someone could give me advise soon b4 winter hits. PLEASE HELP!!! Thanks
Shrink your work area down
In most cases, not all, but most... modern clear coat paints are harder than traditional single stage paints, because modern clear coat paints re harder, in order to remove swirls, which in reality means removing paint, you need to shrink the size of the area you're working down to a smaller size, for example about 16" inches square, basically the size of the average microfiber polishing cloth spread-out.
Then, after working one small area, move on to the next small area to work and overlap into the previously worked area.
For each area, work the ScratchX into and against the paint, put a little passion behind the pad. Most people don't work this product hard enough, fast enough or long enough. Each Saturday out a Detailing classes, after watching how to properly use a hand applied paint cleaner, (ScratchX), we'll often hear people say something like,
That's what I've been doing wrong"
The point being they, like many people have been applying the ScratchX, spreading it around gently and with not focused intent, and then wiping it off only to be dismayed that the swirls are still there.
They don't understand their car's paint, (hardness), they don't understand the technique for removing swirls, (removing paint), and they don't understand how to properly work the product into and against the paint.
This is the primary reason the dual action polisher has become so popular, it takes all the work out of the paint cleaning process, and it takes the need for "user skill" out of the process.
Anyway, if you do a good job of applying ScratchX and going all the way around the vehicle, the next steps are quick and easy because in the next steps you're not trying to remove defects, i.e. you're not trying to remove paint.
The next steps are polishing and protecting and both of these are just applying each product, spreading it out and gently into the paint, for the pure polish you apply it and then wipe it off, for the wax you apply it, allow it to dry and then wipe it off.
Read the articles Murr1525 they'll cover their particular topics in good detail. Here's a couple more,
Tons of information in this forum,
The Information Station
Specifically in these two sub-forums
Meguiar's How-To Articles
Hot Topics
and here's a couple of good articles...
Which products need to dry before removing?
