whats the best way to clean the pads between waxing and polishing? thnks!
how to clean porter cable pads between polishing?
Re: how to clean porter cable pads between polishing?
Originally posted by Hotstartup View Postyea, but i figured by the time i get the whole car with the same pad it will have dirt on it. isnt it recommended to clean the pads in between?Patrick Yu
2003 Honda Accord
2008 Honda Accord EX-L V6
while using if the pad is getting very saturated, take a clean microfiber towel with one hand and turn on the g100 with the other, and press the pad firmly into the microfiber towel. this will help clean it up some...
when i'm finished with the pad(s), i take a bucket and fill it up with some dishwashing soap and let it soak for about 15 minutes and then massage and squeeze (not wring!) all the water and product out and then let it dry on the grit guard...
Originally posted by imacarnut View Postwhile using if the pad is getting very saturated, take a clean microfiber towel with one hand and turn on the g100 with the other, and press the pad firmly into the microfiber towel. this will help clean it up some...
When you have a wide selection of products its hard to keep a dedicated pad for each as the cost gets a little high.Brandon
2007 Black Chevy Avalanche
My Albums: Avalanche
