What do I do with this NXT spray?????
  • What do I do with this NXT spray?????
    I'll admit I might not be using this stuff for the application that it was designed for. BTW what is it? I don't see the point! It's almost as much work as the liquid NXT. Soooo..... I was wondering.... I find it difficult to spread the liquid NXT when I am not using my PC. What if I mixed the spray with the liquid to make it a little thinner? Don't want to loose reflectivity and usually durability is not an issue since I wax like every 2-3 weeks.
    http://www.picturejudge.com/memberpi...flames%201.jpg
    I'd say, ixnay on mixing the two. Some people find the NXT Spray easier to use than the wax; some find it about the same. I find them about the same, but I now use the Spray Wax, and here's why:
    You'll probably wind up getting the worst of both products rather than the best. My guess is that Meg's chemists are very aware of the characteristics of both products, and this is the solution that produces the best combination of protection and beauty.
    I'd venture that the protection offered by NXT Tech Wax far outlasts the stunning appearance. Using the NXT Spray Wax is an economical way to restore and maintain the appearance without disturbing the protection; there are probably far more applications in a bottle of the spray than there are in the wax.
    If you mixed the two, you would probably get the same endurance of gloss, but less enduring protection.
    Tom
      Hi DICEPT,
      First, please take a moment to read through this thread,
      NXT Tech wax + Booster Wax
      It has a lot of comments, opinions, change of minds, and information on using a spray on wax.
      Then, I'm going to take some of the information I wrote in this thread and turn it into a How-To and a FAQ.
      So check it out...
