Glass cleaning
  • Glass cleaning
    What is the best way to clean glass really well and remove water stains. Ive heard some people use a chrom cleaner with a g100,l but i dont have a g100. ANy other ideas?
    '00 Audi A4 1.8 T
    '09 Audi A4 2.0 T Quattro
    Attention to detail is the key to success
    Steve
    Re: Glass cleaning
    I have heard people using QD and having good results, but never tried myself.
    Using a micro fiber towel, with some NXT gen glass cleaner should do the trick. You might need to give it some muscle to get the hard stains out.
    2003 Toyota Celica GT- Silver Streak Mica
      Re: Glass cleaning
      last night i tried claying the glass w/ nxt carwash as a lubricant. when it's dry, i spray it with nxt glass cleaner and it turn out really nice. The best part is that it even looks as if there's no glass.
      Yusri Omar
      Perfectshine Detail
        Re: Glass cleaning
        I have mixed results with clay removing hard water spots on glass. Sometimes it does, sometimes it doesn't. No rhyme or reason that I have been able to figure out. It ALWAYS makes the glass look better though! You could also try some #4 as Mike Phillips suggested a while back.
        Jason
          Re: Glass cleaning
          spot-x this the answer fda appoved find @ homedepot
          Whats my color? Color X
            Re: Glass cleaning
            If you can find it, there's a product called Nothin's Better. It's a paste that comes in a small plastic jar; work it onto the problem glass and buff it off like wax. Even the most difficult hard water spots will be gone.
              Re: Glass cleaning
              Would steel wool work? IM not going to order #4 just to clean some windows. I would however like to remove the water spots. Ill try the clay and see if that does anything. If it doesnt Ill try the wool.
              Would scratch x do anything? #83 with the PC maybe?
                Re: Glass cleaning
                Ok, I spent way too long trying to get rid of water spots tonight. So I knew I could find a better way here. Some very good info in this post. I'll be getting some #0000 steel wool tomorrow.
                Ok. I have tried EVERYTHING on the shelves of every auto, department, grocery and discount store to clean my auto glass. NOTHING has ever delivered a streak free result. My most recent trial was some awful gel type cleaner, but that was WORSE than anything else I have tried. Is there ANYTHING out there that will
                Scott
                  Re: Glass cleaning
                  I've used #0000 Steel Wool a few times with either soap or glass cleaner and it works real well. I think as long as you use some kind of lubricant, it won't scratch. #0000 is real fine anyany. After I use the steel wool, I follow up with a good (Meguiar's) glass cleaner.
                    Re: Glass cleaning
                    I've had decent results with, "cough" toothpaste. Not only for gleaming whites anymore. hehe
                    Do NOT use on inside of tinted window though. Will scratch.
                      Re: Glass cleaning
                      Hey dude,
                      I would use some dilluted CLR and wipe it on with a terry cloth to remove the spots, rinse off ans dry. I finish up with the thinest coat of a fine meguiars wax. DON NOT USE A CLEANER WAX, the abravsive could scratch the glass. The wax will also bead the water as well.
                      JB's Executive Detailing "Protecting your investment"
                        Re: Glass cleaning
                        If I knew the correct answer, I would be owner of many Companies!
                        However, here is my shot with what seems to work really well for a pro-detailer (Thx for the opportunity to educate)
                        The technique that works best for me is the two-towel method: use one to apply and work in the cleaner and the second to buff the glass out. Always spray the cleaner on the towel and wipe versus spraying the cleaner on the glass to avoid creating spots on your dash components. As soon as the second towel becomes damp, don't hesitate to switch to a new one. Also, don't be afraid to use pressure when cleaning.
                        Occasionally, specialized products are needed. The exterior windows often collect mineral deposits (a.k.a. water spots) and insect residues. Most people's cars get the water spots while parked next to sprinklers. Contrary to popular opinion, water spots usually can be safely removed chemically without polishing or strong acids; you just have to have the right chemical. I strongly suggest you avoid abrasively polishing (especially the windshield) unless absolutely necessary, because the procedure can affect optical clarity. To remove new water spots on the glass or paint, try using a microfiber spot-dampened with distilled white vinegar. As far as insect residue, you can use a soft scotch-brite pad (or a similar sponge designed for your non-stick cookware) with a glass cleaner or a good pre-wax paint cleaner (especially a citrus based one) to remove it.
                        Finally, remember that it's much easier to keep windows clean if you keep up with them.
                        Progress is perverting an perfectly good idea!
                          Re: Glass cleaning
                          Hi, Use a WHITE Scourer and Glass Cleaner. The white scourer will NOT scratch glass. As Mike says "use a little passion"
                          Graeme
                            Re: Glass cleaning
                            I tried steel wool and it did nothing. Ive not tried vinegar yet but I may when I get time.. Didnt try clay either..
                              Re: Glass cleaning
                              This certainly raised an old thread from being dead.
                              '00 Audi A4 1.8 T
                              Steve
