More questions :(
  • More questions :(
    The vehicle I've been working on lately is a Yamaha V-Star Motorcycle. In case you don't know what that motorcycle is like, it is mostly chrome with paint only on the tank and the tail. It is a cruiser. Anyways, on to my question. The paint had some pretty bad swirls, so I got out my trusty ScratchX. The area I did was about 1/4 of the tank, and I hit it with passion about 6-8 times. There are still swirls, so I guess it's hard paint. Is there any other product I can use by hand that would work a little bit quicker, or is ScratchX the best thing for the job? The paint has a clear coat as far as I know (the cloth I was using didn't turn purple so it must be clear coat). Or is it possible my technique is wrong? I've had excellent results with ScratchX before but this motorcycle is kicking my butt. The swirls are much dimished, but there are still some there.
    The technique I've been using is put some ScratchX on a 100% cotton terry cloth or an MF, rub it hard on the paint until it is almost all the way gone (just barely a haze left), then wipe it off with a clean section of cloth. Each time I put on another application, I turn to a new section of cloth. Should I maybe be using a different kind of cloth? The terry towels are actually just some old (but clean) hand towels. The MFs are just a brand I got from Walmart. I'm going to try to order from ADS tomorrow, so if there is something that Meg's makes that works better, I can probably order it tomorrow if it's not really
    expensive.
    Also, one more question. The motorcycle paint has some decals on it, but what's weird is they don't seem to feel any different than the paint at all....is it possible that they put the decals on and then clear-coated over them, or is that only something Meguiar's does for their big rig? If they aren't clear-coated over, would it be OK to just put a layer of NXT wax over them?
    Sorry about these stupid questions, but this paint just doesn't seem to want to look as good as I want it to. I want it to be swirl-free since it's such a beautiful paint job (and it's nice to work on some paint that actually CAN look nice without a re-paint).
    Thanks y'all!
    -Lydia
    Lydia's Mobile Detailing
    2007 Honda ST1300 - Silver
    Re: More questions
    have you tried using a foam applicator pad yet? Just work it in like you do with the terry towel accept use a hi tech applicator, after a few applications the swirls should disappear
    a v-star with a 1100CC?
    Patrick Yu
    2003 Honda Accord
    2008 Honda Accord EX-L V6
      Re: More questions
      Thanks for the suggestion; I'll try it today if I have time.
      No but I wish!! It's actually my sister's bike but she lets me ride it. It's only a 650 cc engine. It looks pretty similar to that picture except the tail doesn't look quite the same (and it's purple).
        Re: More questions
        I've used ScratchX a few times, on a couple different vehicles......and it seems like I've had better results when I used a foam app. pad vs. a MF. Of course, there's a chance the difference could have been in the area being worked on and not what I was using to apply it with. But I strictly use the foam pads with ScratchX now.
          Re: More questions
          Lydia what type of towel did you use with scratch x for example a MF towel or a terry towel, a terry towel has more bite to it...
          also to answer you other question about the decals, yes they spray clear over the decals as far as i know it so when you fill up the tank and sum of it spills it wont peel off....
          a pc will help out alot especially with 4in pads perfect combo in my opnion...but since you dont have one see what Rick at ads says, i cannot comment on hand polishes but if you a member of other detailing forums you may get your answer there but if not i guess you can cover it up with a glaze then seal it with a wax or sealant of your choice
          Miguel
          "What you become directly influences what you get"
            Re: More questions
            Sounds like you're doing it right.
            At some point scratches can just be too deep and/or the paint too hard for hand polishing to be practical. It's possible you've hit that wall on this one.
            If that's the case you'll need to decide whether to live with it in the "improved but not removed" condition, wait till you can get your hands on a machine or take it to a pro.
            PC.
