How to remove tar easily?
  • How to remove tar easily?
    As I polish my car using DCS #2 and found that it cant remove tar with it even i try very hard with lots of polish on my cloths, its just cant works. what other product could make this job easy ? Also I founf the DCS is unable to romove swirl marks and fine hairline scretches on surfaces as its stated on the label. I want my car finishes like pro , what pro product I need to use to remove minor swirl mark and hair line scretches ?
    Is not how you shine your car, Is what you shine your car with
    dc#2 wont remove tar or scratches. It is only a polish. Did you try step one of the dc or scratch x for scratches and some type of bug and tar remover for the other stuff.
      You could try GC Bug and Tar Remover. I used to use Extra (which has been discontinued), but this is supposed to work well for... well, bugs and tar.
      - Ben
        Hi Vincent
        I first wash down the area then use Meg's bug and tar remover. I spray it on, let it sit a few minutes, then use a terry cloth to agitate. Depending on how long it's been sitting on the car you may have to do a couple applications to get it off.
        Here is a picture of it in action. Left side you can see the tar breaking down, right side just wiped off with a terry
          Re: How to remove tar easily?
          Hi Spotty,
          Thank you so much for your tips and photo. I will try it as yous advise and let you know the results. Now I knew DCS #1,2,3 doesn't work very on tar and scretches..
            Hi Spotty,
