No. We go through hundreds of all of our pads every year in our Training Garage and we don't have this problem, it's either a quality issue for this pad or a technique issue causing the problem.
Call Customer Care and tell them what you've experienced and cite this thread, they'll take care of you.
1-800-347-5700
Originally posted by BlueLibby04 How do you all get your pads off? Just pull them off or stick your fingers between the backing plate and velcro?
I would think this would be the leading cause of pad failure. I have yet to have a pad and the velcro come apart on me but that is probabily due to the carfull removal of the pad.
Grab the pad on one side firmly and pull it away from the backing plate until you get some separation, then pull the pad off adjacent to the backing plate, not straight off the backing plate, this will help reduce the pull or shear strength between the Velcro and the foam.
All my Meguiars pads I have, some over a year old nowq and used very regularly, are fine - never had deliamination from them. Used on both PC and rotary. Have had a LakeCountry pad do this though...
"A thing of beauty is a joy for ever: Its loveliness increases; it will never pass into nothingness; .... "
