I am new and very interested in this product. I heard and knew what polish is all about but I wonder what Glaze is ? In what circumtances we need to polish and when we need to glaze our car finish ? What is actually different between this two ? Do I still need to wax after glaze ? Glazing is lasting or polishing ?
Glazing and Polishing
Hi Vincent,
The terms glazing and polishing are very similar that they create brilliant high gloss.
The following article will walk you through all 5 steps, and keep in mind once you get to the polishing step, you'll notice there are 2 kinds of polishes.
1) Pure Polishes
2) Cleaner/Polishes
With that said, "Glazes" usually fall into the pure polish even when applied by hand or machine.
5 Step Surface Care Cycle
MikeMike Pennington
Meguiar's, Inc.
800-854-8073
mpennington@meguiars.com
Just to add, different companies use the same words to mean different steps. So dont get confused moving between companies.
Here is a bit of a Meguiars break down:
1. Wash - This is the soapy water step. Mainly to get the big, loosely attatched dirt.
2. Clay - Using a clay bar to remove bonded things off the paint.
3. Clean - Remove dirt from the surface/pores of the paint. Most products have some form of diminishng abrasives to remove swirls as well.
4. Polish/Glaze - Used a bit interchangeably by Meguiars, This is as Mike said, a step to add gloss and depth to the paint by filling in imperfections.
5. Wax/Sealant - Used a bit interchangeably by Meguiars, this is basicaly adding a top coat to protect the surface and seal in your results from the cleaning/polishing steps. Generaly speaking, Meguiars uses 'wax' for carnuba blend products, and 'sealant' for synthetic products.
Hope that helps2017 Subaru WRX Premium - WR Blue
