It seems I was able to kill several birds with one stone...
I wanted to try a couple of different things...
I wanted to practice using a rotary
I wanted to practice wet sanding
I wanted to see, side by side, the different effects various Meg products would have, including different application methods.
...so...
I went to the local junkyard and procured a hood (they were nice enough to donate it to the cause).
DISCLAIMER: Links may lead to large pics painful to dialup...I used detailed pics to better highlight the differences I was looking for...
First, the unprepared hood...
Note the damage...I'll be leaving that for next week...my Bondo experiment!!!
Next is the pic after I washed the hood...it is in the process of drying and I took the picture to try and capture the severity of oxidation that you can see by contrasting the dry vs wet portion...
I then clayed the entire hood...it did a great job of removing the print from the oil pencil, though I had to really scrub to get some of it out...you can see in the pic where even some of the oxidation was removed by my vigorous claying...however, knowing I was to attack more of the hood with much more aggressive products, I didn't try and deoxidize much with the clay...
I then layed a strip of tape on the left hand side of my test section to maintain the 'just washed and clayed' appearance and did a bit more of the hood with my PC on #5 with a 7006 pad using #83 and got this result:
I was quite amazed to see what a significant improvement it made without having to use the rotary!
I then confined my workspace to the center portion of the hood, following the PC #83 with rotary application of #83 with Meg 7006 on about 1850rpm; followed that with rotary application of #84 (again with 7006 on 1850); then #85; and finally went back and buffed the #85 with the PC using #83...in this pic you can see the tape laid out for the progression (after the '85' tape is the final #83 buff, of course):
I removed the tape to note the differences. You'll notice come residue from the compound getting caught under the edge of the tape...I knew it would happen...but I let it stay to mark the edges when the tape came off. It might seem that there isn't a significant difference between the various strips...but I think there is, just keep looking...there are some definite changes in reflectivity between the various applications...
here you can see the light going from the washed/clayed strip to the #84 strip:
and here you can see the light span the #83 with rotary to final #83 buff:
you can imagine what sort of condition this hood was in after sitting who knows how long in a junkyard...what better victim for my first wetsanding adventure?!? I soaked Megs 1500unigrit paper for the designated 15 min in a water and wash solution...then basically went to work. I attacked anything that looked like a scratch or etch which had refused to yield itself to my more humane removal methods. This is the fruit of that labor:
hehe...that was great fun! Of course I went too deep a couple of times...I meant to! I figure if you don't know what too much is, you haven't learned what the product is capable of...
Now for the fun of removing the unigrit marks. I used the rotary #85, stepping down to roatry #83, then to PC #83. I'm pleased with the results...infinitely better than before wetsanding. You can still detect a hint of the lines I used in wetsanding...next time I'll go with a higher # unigrit before going back with the #85 in an effort to smooth the surface even more. Here's the finished results!
And there you have it...what I learned on Saturday...
PS I should note that for purposes of scientific authenticity...all pics were taken in the same location with the exact same lighting
...so...
