I was Bimmerforums.com and somebody kept saying that 80 works great, but ALL it does is fill in the swirls. I think this misinformation started with autopia.org. So I decieded to put it to the test. I know Mike Phillips had done a similar test, but I really wanted to see for myself.
2000 Black GMC Jimmy
Products Used:
Hitachi rotary
Meguiars W4000 wool pad
Meguiars G100 PC
Meguiars M8006 polishing pad
Meguiars NXT Speed Detailier
Meguiars NXT Window Cleaner
Simple Green dilluted about 10:1
2 Alcohol Pads
Meguiars #80 Speed Glaze
Here is the passanger front corner of the hood of my Jimmy before I began any work...
Here is the same area after I blocked of a rough 2 foot by 1 1/2 foot section with 3M blue painters tape.
As you can see the paint was in pretty good shape, so I need to put some swirl marks in it quickly. I used my Hitachi rotary armed with a Meguiars 4000 wool pad. I did not use any polish on the rotary. However, I did spritz the area lightly with speed detailer to provided small amounts of lubrication to keep from burning the paint. I made to "dry" passes at 2000 RPM!!!!!!
Here are the afters, in various lighting. Definetly swirled up..
I then decieded to correct as much as I could using Meguiars #80 Speed glaze and my PC. I made TWO total applications over the entire swirled area to remove as much defects as possible. I have had good luck removing defects (sometimes serious ones) with #80, but I certaintly didn't expect it to all of the heavy marring I installed in the paint from the wool pad.
Remember I made two total applications using speed five. I moved my arm slowly (about 2 inches a second) using overlapping strokes and worked the product for about two minutes. Then I wiped clean and did the final application in the same way
Here are the afters. The Speed Glaze was able to remove/hide 95% of the Wool induced swirls!!!!!!!!!! This from a mild cleaner polish. But are they hidden or removed?????
Products Used:
Hitachi rotary
Meguiars G100 PC
2 Alcohol Pads
