Ive done it by hand many times. It has gotten/ hidden swirls and some but not all of some scratches. Its a good way to simplify your detailing process on your DD if you are too busy to try anything drastic
I wouldn't try to use A12 (maroon bottle) Cleaner/Wax for removing any scratches or swirls. IMO it's too mild for that. It works great on dirt and stains and will leave a smooth finish looking good.
As a consumer product A12 was designed for hand application but you can use a DA too. Since it has negligible cut I don't see a lot of point to trying it with a rotary (I've done it, but not on an automotive finish.)
I used by hand on as quick detail for a Silver Civic that had a huge scruff mark from hitting/rubbing a metal fence..and with some good amount of pressure it took the scruff mark right out. As for the rest of the car it cleaned it up quite well and left a nice finish.
Although I have never use cleaner wax via PC it is suggested to use either polishing or finishing pad. Using the polishing pad will give you a little more cleaning ability over the finishing pad.
Only reason Im using cleaner wax is because there are many paint defects on my car that only a body shop can fix (cracked bumpers, paint chips on hood, BIG PAINT CHIP FROM EGGS, EPOXY ON PAINT!!!). I probably wont be able to get it fixed until winter is over. I want to protect the raw metal from rusting from the salt. Just want to do something quick and cheap for now then do a major detail once everything is fixed.
2005 Toyota Camry LE Phantom Grey Pearl 2001 Toyota Corolla LE Silverstream Opalescent 1996 Lexus ES300 Ruby Pearl
SINCE THERE IS DEMINISHING ABRASIVES IN SOME OF THE POLISHES, IS THERE EVER A REAL NEED TO USE A CUTTING PAD WITH IT, SEEMS THE ABRASIVES WITH JUST A POLIHING PAD WOULD WORK, MAY TAKE A LITTLE LONGER, BUT ALSO GIVE A PERSON MORE CONTROL OVER HOW MUCH THEY ARE REMOVING, ??
keep in mind the Cutting Pad is not recommended for use via PC. So... polishing pad is a good bet.
