NXT Speed Detailer
  • NXT Speed Detailer
    I have been using the Speed Detailer shortly after applying and removing NXT wax. I do this as a final clean-up to pick up any wax dust that is left behind. I understand that the NXT wax has a cure time. Will I upset the wax by using this Detailer ? The vehicles look great after applying the Detailer. They seem to have a touch more gloss than with the wax alone. Brian
    NXT wax does require a window of time to "set up," so you should not use any mist and wipe quick detailer like Speed Detailer on it for at least 12 hours. Best thing to do would be to use a fresh microfiber towel for your final wipe down.
      Wait a day to be safe.
      2003 Toyota Celica GT- Silver Streak Mica
        I might also add, resist the temptation to keep wiping with your microfiber, wipe enough to remove the product and let the finish sit allowing the wax to cure.
        Brandon
        2007 Black Chevy Avalanche
        My Albums: Avalanche
