when should i use Lambswool Pad
  • when should i use Lambswool Pad
    I want to buy a rotary buffer.
    and i have some questions .
    when should I use Lambswool Pad ?
    i want to practice to remove swirl marks with pro line products.
    Re: when should i use Lambswool Pad
    Wool cutting pads are for removing sanding marks and serious defects.
    Wool finishing pads are for following wool cutting pads to bring the finish up to a higher standard.
    Both will leave swirls in the paint and should be followed by re-polishing using a foam pad
