need advice on how to remove commercial axle grease on paint
  • need advice on how to remove commercial axle grease on paint
    I have a friend that has comercial axle grease
    on his paint was wondering what the best way to get it off
    the paint without damaging the paint.
    thanks
    sprbst
    No matter what you use you'll have to wax the area of concern upon removal of the grease. I'd try some body shop solvent (prepsol). Good luck.
    Death Before Dishonor
      A bug & tar remover. There is the Gold Class one, and there is also Body Solvent in the detailer line.
        Kerosene would work well, though you'll have to wash the kerosene residue off afterwards.
        Mr. Miyagi says: "Wax on, wax off"
          I have used Castrol Degreaser to axle grease off of my old car one time. I had to rewax the area of course, but I didn't have to worry about an oily residue from the axle grease anymore. That Castrol stuff is great and you can dillute if you want. I sprayed it on full concentrate and then washed it with some car wash soap and water mix.
          2016 Focus ST
            Thank you all for the help,
            the castrol degreaser worked GREAT on breaking down the grease.
            sprbst
              Great to hear it worked for you. Make sure you rewax that area again.
              2016 Focus ST
                yup put two thin coats on after i washed the car.
                thanks,
                sprbst
