Care
  • Care
    How often do you guys wash your MFs and WM's and such? After every wash? Occasionally?
    MF's I wash after each use. Especially if I've just QD'd or cleaned the windows on my Jeep. I figure the more particles that become trapped in my MF's, the more potential for micromarring and the less effictive it becomes at doing its job.
    WM I wash once in a blue moon. I normally will soak them after each wash for about 5-10 minutes in APC/ Carwash soap, but rarley will I stick them in the washer.
      Really? I thought the same too, because after using my WM only 2 times, it still felt the same as when I first got it. But I still washed it because it got dirt on it.
        By the time I've finished soaking the WM, theres not much left on it, so I see no reason to wash it. Sure If I pick up some dirt I'll either soak it longer or wash it. I'd rather soak mine and get most of the grime thats left out that way, then put it through an abusive washing cycle more often... Others may disagree, but to each his own...
