will this work?
  • will this work?
    i have 3 products and would prefer not to buy any more but will if i have to.
    deep crystal paint cleaner.
    KITTEN liquid Polishing wax (carnauba)
    NXT tech wax (liquid)
    my car is black and has swirl marks and some of those surface contamination marks (not much). it also has a coat of nxt wax over it.
    so i was thinking using the 3 products in the order mentioned to get it looking good.
    will this work well?
    also will the cleaner get the coat of wax off or do i need something else?
    1 more thing, which pads do i use with each pruduct? i have some meguiars soft foam pads and a denser foam pad.
    thanks in advance.
    Greg
    Are you going to be working by hand? Without scratch X I don't think you will be able to get swirls out by hand. Here is a good thread to read for how to remove swirls by hand...
    How To Remove Swirls By Hand (http://meguiarsonline.com/forums/showthread.php?s=&threadid=7011) The below write-up was taken from page three of this Saturday Detailing Class at Meguiar's where approximately 25 people witnessed the products shown below, applied and removed using the correct techniques to remove the
    The Meguiars G100 or Porter Cable 7424 would be much more effective at the removal of Swirl marks. And if your paint is exceptionally hard, a Rotary buffer would be your next method though this wouldn't be recommended for beginners. The G100 or PC are pretty easy to use and anyone can use them. They will greatly reduce your work.
    -Brian
    2007 Obsidian Black IS350
