M85,M80 and Carnauba wax
  • M85,M80 and Carnauba wax
    Just wont to no if this would be suitable to use on a very bad bad swirled black 4X4 ?? M85,M80 and Carnauba wax
    sorry no pictures at moment it dose not turn up till next week
    Would this give me a very clear image ??
    or would you recommend another approach to use
    This 4X4 would have to be the worst looked after wagon i have seen yet
    The owner wants to give it a big birthday
    Now that is everything on the outside glass,plastic and alloy bull-bar
    This will be a 2 day job i reckon
    If it turns out right there will be more things in the pipeline to polish
    All the info will be much appreciated
    Thankyou
    Have A Smurfie Day
    Take Pride In Your Ride...
    sorry forgot to say i have a rotary and a cyclo buffer to do the job
    also have wool and foam pads
    Have A Smurfie Day
      From what I read on this site, #85 is for use with a wool pad and #84 is for a foam pad. Both are used with a rotary. IMO, if #84 is recommended for removing wet sanding marks, this system will work fine for your job. I would use #84 with a rotary and foam cutting pad, #80 with a rotary and foam polishing pad, #80 again with a PC and foam polishing pad, and finally a wax/sealer.
      Watch your pennies and your dollars will take care of themself.
        thank you for the info
        sorry about the double post
        Dam cat jumped on the keyboard and did not realise that it got posted
        Tried to remove it but it but i could not
        Have A Smurfie Day
          M85 with a wool pad and an ocilating sander is going to be very very abrasive.
          M84 is quite a bit stonger than M83, yet M84 is still a lot safer and also a foam pad is going to be a lot safer than M85 in that it has less power. Also consider using a DACP if you can.
          Unless you have very very hard paint, M84, DACP, and Foam Pad is the strongest you should be going too.
          I have used a G-100 with M83 and the 8000 series pad. I have not needed to go stronger than this.
            Good point on the #83. If you are good with a rotary I believe #84 will work fine and it will be faster. If you are nervous then stick with a lighter compund which will give you more time before damage occurs.
